Part number or link please?Nothing wrong with that harness, but I have a Rebel Wire harness in one of my cars and it’s excellent and about $100 cheaper.
I have a 302 form an 89 mustang, I am not sure if I will go with the stock intake/EFI. I am thinking of going with a mild cam and a Summit 500 EFI.[email protected],
What are you using for powertrain and induction? The answer to that will dictate what I recommend regarding a harness.
Either FFR or Summit. Summit has springs by dimension and rate. Yours are 450# so that or 500# will work. Measure the overall length and the ID. They look like they may be 10 inches. And the ID is probably 1 7/8 or 1.875.I am ready to put the front suspension together and was reading through some documentation. It turns out I have the recall front coils springs . Can anyone tell me where to get a replacement set? View attachment 360256
It's not the springs that are the problem, it's the Bilstein shocks themselves which were prone to shaft breakage.I am ready to put the front suspension together and was reading through some documentation. It turns out I have the recall front coils springs . Can anyone tell me where to get a replacement set? View attachment 360256
Thanks, I Have plenty to do while they are out.Because I am in Canada FFR cannot sell me shocks. I wanted to defer dropping that much cash for as long as possible so cut 4 pieces of 1” square tubing and drilled holes in each end and assembled my suspension with these in place of the shocks.
I even drove the car out of the garage and on to a trailer to move it around with these installed.
Don’t let it slow you down!
