361 - 375 of 375 Posts
I think this weekend's episode of "Muscle Car", showed how to deal with paint imperfections. If I remember correctly, they suggested letting it throughly dry, then scraping it with a razor blade, then sanding and finally buffing.
I saw this episode as well and they seemed to be able to fix some real bad issues. Here is a link, not sure they have a vid on yet, Check Spike TV for reruns.
http://www.powerblocktv.com/site3/index.php/musclecar-episodes?ep_num=MC2010-09&ep_sea=1001
Here is another link for color sand. http://www.youtube.com/watch?v=j3rj9FYh8U4
Scott, its looks amazing, you are doing a great job and really are inspiring us. Can't wait to see it all together.
Chris.
Any updates? I'd love to see a picture of the car fully assembled, and out in the sunlight..:001_smile:
Couple questions.
I keeps seeing ideas on prepping "seams". From what I gather these are not really seams per say, but actually marks left from the mold, (as the body makers were to lazy to prep the mold properly before shooting the gel-coat. Can you simply just not sand these down to the same level as the body, rather than grinding them out, so you have a smooth surface? I don't understand the need to grind them. I have read where it says you need to remove any gel-coat, but the whole body has gel-coat, so...??
If one simply wanted to knock down these mold marks, and shoot the car with primer (for temporary driving), would this cause problems in the future for a proffessional bodyman/painter to do the finish work? Would I be better to simply leave it as delivered till it goes into the body shop? I just though by using a tintable primer, even though it would be flat, it would look better in the meantime.
Can use use polyurethane paint on these bodys rather than the base-clear, (which I think is acrylic paint?). Would the polyurethane react with the vinylester resins used in the body? I have heard poly paint is the toughest for resisting scratches, that's why I had thought of getting it painted in that product.
I may still end up doing the bodywork/paint myself, but I wanted to get a few quotes first, from some pros before deciding.
Discussion starter · #363 ·
Bill,
To answer some of your questions with my self-taught knowledge (I'm by no means a body man expert).
You could sand down the mold "ridges" we call seams. As you pointed out they are not like those on the older corvettes where panels of the car are glued together, but you are spot on with the description of what this is. It's flash or excess gel coat and layup that fills in the edges of where the different sections of the fiberglass mold come together.
The one problem I experienced with just trying to knock these down is the inevitable "air pockets" and "voids" that get uncovered when you start sanding these areas. The other issue is the alignment of the Mk 3 / 3.1 bodies (still better than the Mk I and II's) you will see high and low spots where one side of the "seam" does not align with the other.
I did not use any HSRF in my prep, and I also did not do the aggressive grinding down into the seams that a lot of builders did with the older bodies. I found no gel coat penetration down into these areas, and simply leveled, then used gold body filler (polyester based) to do the fairing and surfacing.
You could try your idea, but to spray the car with primer, just to drive for a little while is not worth the effort. I would either go all the way, and just commit to doing the body work in the correct stages, or leave the body as is and drive it for a while to work out any problems and then tackle the body work at a later date.
However, if you want to just level and spray the seam area to make it look better, I would suggest using only 2k epoxy primer for this work. People will argue with me that rattle can black primer or paint is okay, but that stuff is inferior, and uncompatible with 2k urethane paints.
I would also stay away from acrylic enamels, lacquers, etc. These cars grow and shrink with the heat and cold, so you really want to use a modern urethane paint for the best longevity of your finish. Urethane is essentially a flowable hardened plastic paint. All of the OEM auto makers use it now, and it virually eliminates the need for flex agent additives.
If you want any more of my advice, for what it's worth, feel free to PM me. I'm still learning, but have learned a lot from what I did with this car.
P.S. - final outdoor pictures of the car reassembled can be seen soon in my "GRADUATION THREAD". For now, this will have to do:
Scott
Just awesome.
I'm going to work on mine right now :)
Thanks for the advice Scott.
The car is really looking great! Nice to see that it turned out so well, after all the hard work. You must be thrilled..
Great job Scott!
I've just got to add a little icing as this thread winds down.
I got to see Scott's car in person at LCS this weekend and as good as the photos look they don't tell the whole story. The body work is flawless. Not a ripple to be found, the cockpit roll and scoop extension look perfect. Excellent color choices; photos can't capture the life and pop that the blue & silver have in sunlight and the splash of red truly sets it off. Scott hasn't cut or buffed yet and still has an easy 9 out of 10 finish! After he does that it will go toe to toe with anything the pros turn out :drool:
Scott has proven that with determination, research and some of hard work it is possible to turn out an outstanding finished product from home! Any of you guys who are on the fence about doing it yourself should use this thread as inspiration. Oh, don't forget to thank him for taking the time to chronicle it all into an excellent guide too! :yes:
I just finished reading all 10 pages of this thread. I am convinced and itchy (?) to do my body work but am still hesitant about paint. I think your cojones will stay larger than anyone else's here.
Great job and thanks for the well documented thread and inspiration.
Since this thread popped up again:
Scott, could you give some more detail on the actual spraying part of this?
How do you get even coverage on all the nooks and crannies of these bodies. Did you lay out a grid of some type and go front to back, or did you do the small, hard to get to areas first then the big areas or what?
Inquiring minds want to know...
(or at least I do)
Discussion starter · #370 ·
Hey Dallas,
Sorry I missed your post and recent question, and thanks for the PM reminder to check this thread.
To answer your question...well it was really not that complicated.
I have another thread on my actual painting progress as this thread was getting long winded (sorry guys):
Painting Progress for STL-Scott
What I did was to start on the stripes first. Then taped them out. Switched to the body color (silver) and worked from the stripe area out to the side of the body. I think I started at the rear of the car first since that was closest to my exhaust fans. The idea being as the overspray was drawn out of my garage any particles that landed on the car would fall on already wet paint vs. an unpainted area which would cause problems.
You will hear tips on how to do the wheel wells and little crevises that are vastly different.
If I recall, I ended up painting the big areas of the body first and then hit the wheel wells and openings last. For me this helped reduce the chance of overspray runs at the openings.
HTH,
Scott
Hey Scott
i am the new moderator i am going to close this thread:wacko:its too long and after i read my posts, i thought did i really type that:001_tongue:
now aren't you glad a couple of home boys pressed you on..................>>>:smoke:
Discussion starter · #372 ·
Oh...come on Leo, where's your spirit? This thread of mine is almost 1 year old. I think I will keep posting some of my 'cut and buffing' progress to this thread to make a complete sweep of it.
And yes...your typing could use soem wokr...looks wohs taklnig :wacko:
my spirit is always there Scotty just thought i would add some more post and give you some Sh!t, and typing i am just great with that the one finger pounds can do 45 WAM :w00t:now spelling it has got to do with how many beers i had after work.
Is work good there for ya in OH10, its been picking up here but still a lot of tradesmen out of work. some have taken jobs in afganistan.
Hopefully you get a notification for this question... do you have this thread saved off with pictures that are not so blured out? Its a photo bucket issue I’m sure... like zip it up and email it? Alot of great information detailing things and the photos are junk...
