Tips/prep for fitting the body for the first time
4.4K views 9 replies 6 participants last post by  silver_pilate
#1 ·
Well, the time has finally come to move the shop, including the roadster, to the new house. The chassis is almost in roller at this point, but no operational brakes just yet (going to re-do the brake lines in a single piece). In preparation for loading the car onto a Uhaul car trailer, I’m going to mount the wheels/tires and get it standing on its own for the first time. I’m also going to mount the body and take it over all together. While the body is mounted, I’ll figure out the dash mounting solution that I want to use and locate and mount the seats.
In prep for mounting the body, I’m going to put on the weather stripping. My question is what else should I do to get ready to test-fit the body? Am I going to need to trim back the rolled edges on the front and back of the cockpit? I’m on Jeff Kleiner’s waiting list for all the body work sometime early next year, so I don’t want to do more than the minimum on trimming the body in order to leave him all he needs to get it right.
Also, any problem with mounting the wheels/tires prior to mounting the body? Wasn’t sure if it was easier one way vs. the other.
Thanks for the tips!
—Nathan
#2 ·
Shouldn't need to trim the cockpit edges unless you had a finished dash mounted.
The only thing I had trouble with on my first body back attempt was that I made my own lower radiator support and the brackets I made interfered with the chin of the body. So it was body back off and 2 minutes with the death wheel and then body back on.
Wheels and tires should be fine. We put the body back on mine with go-kart sitting on her own feet, but you may find that you have some rubbing between the tires and fenders depending on ride height and steering deflection. Be careful loading...
Kyle
#4 ·
I agree with Rich; don't mess with weather stripping until you're ready to leave the body on for good.
#6 ·
Well, actually the bulb seal needs to be on for the "real" body fitting and shaping. For now to make the move just throw it up on there and secure it pretty much like how FFR had it when it was delivered to you. Tires on or off won't matter (they're always on when I'm installing or removing a body). As you roll the car onto the U-Haul trailer watch clearance between the car's oil cooler scoop and the rearmost crossmember of the trailer. You may need to raise the tongue of the trailer to flatten out the ramp angle.
Good luck,
#5 ·
Enjoy looking at it "dressed" for the first time, and ponder the future!
#7 ·
Thanks, guys. It make sense not to do the weather stripping now as it's not critical just for seat placement. Now I just need to go back and review threads that talk about the best way to get the body on. I've got a couple of helpers lined up so I'll just need to be able to direct the show.
I'll get some pictures posted of the new shop once I get it put together.
--Nathan
#8 · (Edited)
Oh, speaking of loading this on the trailer, what's the best method you guys have found for the Uhaul car trailers? I guess my biggest question is where do you push from on the rear of the car (if at all), and/or do you use a come-along/winch? It just doesn't seem like pushing hard on the rear of the body to go up a ramp is a great idea.
Sorry for the questions. This is the first time it will have moved in two years and the first time I've had to load up a non-running vehicle on a trailer.
#9 ·
Nose down and pulled over the triangular frame extensions with the tail held high. Come rearward and down with the back while spreading the sides as necessary to allow the rockers to clear the door hinges. I hang them from the shop ceiling by their four corners and do it by myself all the time but if you can round up 2 helpers it will be a piece of cake! As for pushing---stick a roll bar or two in it (just the hoop, no need for the rear leg); they make great handles :)
#10 ·
Thanks, Jeff. Great idea on throwing on the hoops for push handles.
