During driveshaft installation ten years ago we had to pound the shaft into place for rear end (4-link) bolt up. I now need to replace a leaking rear seal and address the tightness when inserting the yoke into the T-5 transmission. Maybe the yoke is oversize or I left the foam/rubber plug in the transmission.
Spent past two weeks using heat and WD-40 trying to remove the driveshaft bolts. Yesterday, two heads came off and one partial bolt. Expect the last to come off today.
Since the shaft is in very tight, what is the best approach to removing the broken bolts and shaft? Should I drop the rear end to drill the bolts out easier?
Thanks, Nate
FFR #5974 BRG (PPG-Subaru Green), 306, 93-GT-40 heads, E-cam, 24lb injectors, 93-Cobra intake, 70MM throttle body, D&D rebuilt T-5 trans, 3.73 rear, North Racecars A/C, Firewall Forward and expanded footboxes, Kirkeys, CobraEarl Trunk, wipers/washer, Custom Tonneau cover (Phil & Kay), FFR Softtop and 15" Cooper Cobras.
Thanks, Nate
