okay everyone knows this car isn't exactly forgiving. a couple of times, going around a mild turns onto freeway on-ramps, i hit it relatively hard in second gear going about 20mph. the back slid out just a bit, not too much, but enough to take notice. with a very mild 306 in a car like this, it doesn't seem like it should break loose so easily.
i have 3.08's and waiting for funds to have them changed to 3.55's. if i do this, will the problem be much worse?
but then, it may not be a "problem", just normal, and i will have to take it easy and/or learn to drive better. at the current moment, i can't picture myself on a track even at mild speed, because it slides out so easy.
i wish i knew more about the 3-link when i ordered way back when. my rear end setup is on the lower end, stock mustang axle with VPM coilovers (which help tremendously, by the way.) 315's, 17".
my rear ride height is 5", i just like it a little higher because the tires look a little better in the wheel wells. will dropping it to 4" be better?
-some sort of a sway-bar?
-better tires someday? i have Sumimoto, no traction rating on the sidewall listed
-like i planned, re-align steering to power steering specs? (used manual specs in the build-book)
-anything?
-even harder springs on the coilovers?
if none of these things will help, and if the new gears will make it worse, i may as well just leave the gears as-is. please let me know options...
-anything?
