Fuel Inertia Cut-off Switch
2.6K views 15 replies 10 participants last post by  BigUgly
#1 ·
I need some advice, gents: I replaced my stock distributor with an MSD and my stock throttle body with a 70mm BBK (old parts were good - just wanted upgrades). Everything went smoothly afterwards, including a short test drive. I drove another 20 miles and parked for an hour, then got in and the engine started normally but died after driving about 75 feet. After a lot of checking and testing, it turned out the fuel inertia cut off switch had been tripped. I reset it and everything is fine, as far as I can tell.
What did I do wrong?
'94 donor engine with factory EFI
#3 ·
Which way did you orient the switch ? I had mine mounted "vertical" at first, after it tripped twice, I made a horizontal mount. I can still trip it by hand with a good tap, our famous Pa potholes haven't.
#5 ·
Follow up:
You guys are right, thanks for that. I thought my engine work was related to the inertia switch and I didn't consider anything else. I was in a parking lot that has some bone jarring speed bumps so that's what did it.
On a related note - I understand most cars don't have this type of device and I can easily isolate it out of the fuel system by cutting the leads and shorting them together. I plan to do that.
On a another related note - Speed potholes slow me down a lot more that speed bumps!
#6 ·
Follow up:
DONT. If you should ever be in an accident, the fuel pump could continue to run, causing a serious fire hazard. All fuel injected cars have inertia switches.
#13 ·
I don't know about a "ton of complaints"; I have not personally found nor have I heard reports of them being problematic. I mounted mine, an OEM Ford part, on the 2X2 tube behind the dash where I can reach it when belted in. I can give the chassis a solid hit with a deadblow hammer and trip it yet I have never had it trip after hitting some bone jarring bumps or potholes on the street as well as several off track excursions into the weeds. In my own case it is doing exactly what it was designed to do.
#16 ·
Jeff,
Thanks for the reply. Also, you don't know how many times you have responded to someone's question and helped resolve their problem while at the same time I also could use that same advice and it has saved me from doing something over again.
I just want to say, as far as I'm concerned, when Jeff Kleiner talks, I listen.
BigUgly
