The engine mounts I ordered with the complete coupe kit were for the 351 engine. As to the manifold, I had sent pictures off to blueprint of the manifold to verify it was the right one and there confirmed it was. The hood will fit without an air cleaner. I've been trying to find an air cleaner that would fit. I ordered a drop base 13" round air cleaner from Summit and that is still to tall.
I'm leaning to something with the motor mount alignment. I will take a closer look. Thanks for taking the time to give some input.
OK, the air cleaner side should be 14", sniper has a specific base. That and a K&N 2 3/8 filter and filter top should work well. If your oil pan is above the frame rails a set of my powering engine mounts will add another 3/4" of clearance.
Exactly what manifold is it? i.e. part number? There are different heights; some of my customers have run into issues when using tall Air Gap style intakes on the taller deck blocks.
Definitely. I generally use a torquer II intake on coupes.
Related Threads
Factory Five Racing Forum
posts
3.3M
members
54K
Since
2002
