If I am using 2 turn signal indicator lights(l-R) on the dash (instead of 1)then it seems I do not need the diodes mentioned in some of the diagrams people have posted right???
The facility to use 4 brake lights/4 turn lights is usually built into the turn signal switch circuitry. How do you keep your brake lights from blinking when not turning and what happens when you step on the brake with the turn signal on?Originally posted by mlagace:
I'M USING A THREE WAY TOGGLE, ON-OFF-ON, WITH TWO INDICATOR LIGHTS IN THE DASH. BECAUSE I AM USING ALL FOUR REAR LIGHTS FOR BRAKES, AND TWO AND TWO FOR L AND R TURN, I NEEDED TO WIRE IN THE DIODES TO ELIMINATE FEEDBACK.
