S/C would be simpler and less expensive, but turbos are more efficient. If you are racing, S/C's build up ALOT of heat.
The newer designs of the centrifigal S/C's are approaching the efficiency of a turbo. A roots style would be best for instant response, as a centrifigal has a little lag (not like a turbo though), but you won't be able to fit a roots style under your hood.
Whatever route you go, make sure your motor is built for it (forged internals, low compression, cam/heads matched for it, etc).
