It'll be a while before I need this info, but it's one of those thoughts that just hangs in the back of your mind and zings you regularly. What are the correct tire pressures for the GTM? The GTM uses Corvette rubber(for the most part) but weighs about 2/3rds of a Corvette, and has a different weight distribution. Seems to me if you use Corvette pressures, your tire "patch" will be smaller, and you'll loose traction and handling capabilities. Is there a way to calculate the correct pressures, or is it purely a matter of trial and error? Best regards, Ted
