I've seen circuits that use the switch to supply power to the component. I've also seen circuits that use the switch to supply either power or ground to operate the solenoid of a relay. Does anyone know the reason behind this? I have a 50 amp switch that is supplying power to the ignition system (maybe 10 amps). I wonder if this is ok or if I should add a relay so the switch is only supplying power or a ground to the relay. Is the relay over kill in this case or a good idea? Sorry for all the questions the electrical install seems to present alot of choices.
