I've had my car on the road since last summer. I had issues with the rad hoses leaking and popping off, which I figured was my Coolflex hoses. I replaced them with a plain rubber hose. When I drive the car, the temp seems OK. When I drive on the highway for 10-15 miles and cools down, the overflow is empty. I suspected I had a blown head gasket which was pressurizing the cooling system, forcing the coolant out the overflow. I tried a kit from Autozone which is supposed to detect combustion gasses in the coolant, and it came back negative. At that point, I put the car away for a while. I recently got some ambition, and acting on a tip from a tech, I pulled all the plugs and pressure tested the coolant system. It held 15 lbs for 15 minutes. I've read all the head gasket threads, but I'm still not sure. If I had a head gasket leak, shouldn't it show up on the pressure test with all the plugs out?
