FFR's original method of using the side support brackets was causing many issues with the welded mount on the side pipes cracking. Seem the engine torque wasn't taken onto consideration, and the bracket didn't have enough give, so it stressed the weld. In some later cases, even when the support was allowed to move slightly, if it was mounted incorrectly, it would contact the frame, thereby preventing further movement, when under torque. Eventually from metal fatigue, the welded pipe mount would again crack..
A few builders worked on the problem, to allow the bracket to have maximum flex, and mounted it so there was no chance of it hitting the frame. The backet didn't actually offer much support mounted this way, as far as taking any weight. But it could help with the stress on the headers, when inertia forces are at work. The thinking was that this may help prevent the natural centrifugal forces, wanting to whip that large weight out sideways during hard cornering. It make sense as you have 40-50lbs, hanging off of just eight header bolts. There has to be quite a bit of stress on the header flange. Regardless, this flexible hanger mounting method, seemed to end the cracking issue.
This is one way it was done.
This next picture is the current way FFR suggests mounting the bracket. If you do it this way, only use one bolt on the sidepipe, and leave it slightly loose (nylok nut). Also don't crank down hard on the bolt on the end of the hanger, where it attaches to the frame. Flexibility is key.
