Gtm ignition
438 views 9 replies 5 participants last post by  Shoeless
#1 ·
Hey guys, just picked up my 2007 Gtm two months ago. Unfortunately the ignition has gone out on it any help on how to access it without tearing the dashboard apart would be greatly appreciated. Thank you.
#6 ·
That is not the ignition switch that comes with the GTM kit.....and also not the normal place to install it. I'd say you're probably going to have to pull the dash out, get the ign switch out and see if it has a part number on it or any way to identify what it is so you can buy a replacement.
On second look, it does appear that there is a plate that your AC controls are installed into. Instead of pulling the dash, you may be able to pull that plate off and hopefully have enough room to reach your arm back in there to get to the ign switch?
#8 ·
These cars are all custom built, so there is no "standard" place for screws. Most likely, you'll need to begin with removing the instrument cluster and then using that opening to go in and remove the screws that hold the driver's side dash pod to the main dash. Once you get that dash pod out of the way, hopefully you will be able to figure out what else is holding the main dash part in place. Have you tried to remove that plate that surrounds the shifter to see if you can access the ignition switch thru there?
