what belt size after FRPP A/C eliminator bracket is used?
1 reading
372 views 4 replies 3 participants last post by  Ophitoxaemia
#1 ·
Hi - what size belt do I need to get after using the FRPP A/C eliminator bracket setup. This is the one that moves the power steering pump up to where the AC was, and not simply replacing the AC with a pulley (which presumably would use the stock size belt). The rest of the front of the engine is stock with smog pump etc.
Howard
#3 ·
What engine?
#4 ·
Its a 302 - I realized right after I posted it that James has the right idea - I should just measure it and buy the 2 belts closest in size.
#5 ·
incidently, i found the 'right' size was tight enough so its a bit of a bother getting it on. the belt will stretch a fair amount so the tensioner needs to start out at the tight end of the range. YMMV,
james
