Trunk Side Walls
1 reading
795 views 4 replies 4 participants last post by  John Dol
#1 ·
I am looking to fit the trunk side pieces before fitting the body back on to the frame and I did not see a lot about how the top piece connects up toward the roll cage. By the look of things, it appears that I must bend the piece to fit the contour of the roll care (flat section) and then during final assembly this side piece would be riveted to the flat section of where the roll cage meets? Is this correct? or am I way out of bounds....
#2 ·
I'd be interested in seeing what others have done, but my plan is to rivet that to the body, not the roll cage/frame. It seems to sit flush on the body and will seal up between the trunk and body.
See pics below:
Thanks.
-Matt
#3 ·
Trunk Side walls
Hey Matt,
based on the photos, it looks like they made a change to the roll cage. it looks like you do not have the flat section like on mine?
Hopefully a few others chime in or maybe a e-mail off to FFR. Thanks
Chris
