I found a 10 K OHM resistor at Radio Shack all they had was labeled 10 K OHM, 1/2 watt. Is this OK? I disassembled the plug and soldered the resistor into the pins and my code # 85 continues to show up on my KOEO test. I believe I used the same resistors on the TAB and TAD removal on Evans Build site and I recive no codes.
