Help removing poly bushings from lower control arms
279 views 5 replies 4 participants last post by  1686
#1 ·
Trying to remove the poly bushings to slot and grind them down for a better fit. Do I need a press to first remove the sleeve for this or is there any other way to do this? I tried a 3 jaw puller but it couldn't get a good grip. I'll probably have to do it a few times to get the fit right so I'm hoping there's some way I can do it myself without having to buy a press. Thanks.
J_B
#2 ·
I know I can't do it justice but I used a bolt through the center. I put large fender washers on the bushing and a PVC reducer pipe fitting around the bushing on the other side. A piece of steel (an old edger blade) more washers and the nut.
Use the nut to pull the bolt ....
I stipped a couple of the course thread bolts - 3/8 or 7/16" you might do better with finer thread bolts or threaded rod.
#3 ·
I just did that this afternoon! I was getting a squeaking sound from the poly bushings whenever going over bumps.
All I did was put one end at a time in a vise with soft jaws (so as not to damage the powdercoating). next I took an extension bar for a 3/8" ratchet and used the large end (which is the right diameter) againt the steel bushing. I then tapped it out with a rubber hammer to not damage the extension. Once the steel bushung is out the poly pieces come out pretty easy. There are 2 outer bushings, and a spacer piece in the middle.
To reinstall them, I just tapped the bushings back in place with a rubber hammer against a block of wood on the opposite side. Then start the steel bushing in the hole, and press it in the rest of the way in between the vice jaws.
[ September 14, 2003, 10:56 PM: Message edited by: B+L FFR 1686 ]
#4 ·
Sort ofa different twist on the subject, FFR only sent me two bolts for the tubular control arms, 12mm, well I thought they should be 1/2" grade 8 so I drilled out the bushings, not a problem tho' the bushings wanted to come out while drilling, guess they should be easy to remove.
#5 ·
Thanks for the ideas. What did you guys use to grind the bushings down? Did you use a grinder or a sanding block or something else? Thanks.
J_B
#6 ·
I mounted them on a mandrel and tried to turn them on my lathe, but the material has way too much compliance for that regardles of the different tool bits that I experimented with. I ended up just using a new razor blade to cafefully slice the material that I wanted to remove. Keep in mind that the way they are designed, the grease expands the outer bushings like a piston in a brake caliper, so be caeful not to over pump the grease - it doesn't squeeze out like it does with dust boots!
