Hi All,
I’ve started to update my car to race prep it to run the Mojave Mile speed events and would like to try running the “Silver State” classic event in Nevada.
I want the car to meet the A2/A3 class rules. This forum is about the best place for technical help and suggestions to prep the coup for high speed. Here are some of the updates I’m planning for the car:
• Fabricate some sort of air splitter to the front to help with front end lift. Any ideas?
• Fabricate rear air valiance.
• New side windows w/ adjustable support struts with upper latch similar to a NHRA pro stock car.
• Install window net.
• Thinking of adding an adjustable lip to the rear spoiler.
• Possible rear gear change? I currently have 8.8 with 3.55’s, .64 overdrive with 25.6” dia. rear tire. Engine redline is 7000 to 7200 rpm. I don’t want to run out of gear; I need help choosing the correct rear gear ratio for a one mile run.
• Update to rear axles to add “C clip eliminators”
• Add safety hold down pins to rear hatch window.
• Add two addition hold downs to front bonnet?
• Progressive controller for the nitrous system.
• Oil pressure safety switch to shut down fuel pump in cause of loss of oil pressure.
• Inertial rollover safety switch.
• Fresh air box to feed carb.
• Add diaper around oil pan.
• Drive shaft 360 degree safety loop.
• Racepak data logger to record Engine RPM, Driveshaft RPM, Battery Voltage, 2-Axis G-meter, 12 volt event, O2, oil, water, temp, etc.
• Parachute and mounting, control cable and chute pull handle. This isn’t needed right now and can wait until I work up to required speed.
• Fabricate anchor for chute pull attachment.
• New dash layout for better gauge visibility.
• Stepper gauges w/ programmable warning lights.
• 200 mph GPS speedometer.
• Fire bottle system.
• Go Pro video.
• Possible wheel change if pin drives aren't legal. Probably are some pro & cons with related to running pin drive wheels?
Here's the current engine specs:
• Engine type: 302 based small block ford
• Displacement (cu in): 347
• Bore x stroke (in): 4.030" bore x 3.400" stroke
• Block: BOSS 4-bolt Main Block 302 397-M-6010-BOSS302 - 8.2-inch deck height . .010" below piston to deck height (nominal)
• Crankshaft: SCAT Forged CM Steel: 3.400" stroke
• Connecting rods: SCAT forged CM steel I-beam connecting rods
• Pistons: Mahle forged aluminum pistons, with reliefs for Z304D, Z304P, N351, GT-40 and other inline valve Windsor cylinder heads. 6 cc valve pockets.
• Hydraulic roller camshaft compatible
• Balanced: Internal
• ARF CNC'd heads, 185cc, P/N AFR1388
• 58cc chambers, 10.7 to 1 compression ratio
• Spark plugs, Autolite 3824
• Victor jr. intake manifold, jet hot coated
• Holley HP Ultra 750 carb
• Comp Cams hydraulic roller cam serial # M 0832-07, P/N 35-000-8
• Gross valve lift Intake .566 Exhaust .579 lube separation 110 degrees
• MSD Pro Billet Dist - 25 degrees advance silver light springs
• 125 HP shot of NOS
Anyhow, any feedback, help or suggestions will be apreciated,
<alex>
• Go Pro video.
<alex>
