Hello all, I have a problem with the alignment of the headers to the body cutouts. I'd like to know how you guys managed to line the headers to the body holes. My setup shows that I have the driver side header way off high while the passenger side is acceptable. I don't want to make the hole bigger on the driver side as it would be like 1 3/4 inch bigger hole! The bottom of the body wraps around both floors perfect. The engine seems to be ligned up and level. Did you try or requested a replacement header from FFR? aren't they all the same anyways?
If i move the engine tranny around to try to line one side , the other will be off or they will both be off.
I need a solution, how did you solve this?
Jean
Jean
