GTM Location of OBD conector
1 reading
1.1K views 2 replies 3 participants last post by  turboguy
#1 ·
Hello, Hopefully someone can help me. I purchased a completed GTM and it seems that the pass key system is lousing up. The car will start and run fine for a while but if I shut it off it wont start. It starts, runs for 2 seconds then shuts off until I let it sit for 10 minutes. My mechanic cannot find the OBD connector to get into the computer and look for codes. I know all these cars are built differently but is there a likely location for the OBD connector? The computer and fuse block are mounted to the passenger side of the engine compartment.
Thank you
#2 ·
Most people put it where the manual says... to the right of the steering wheel under the dash on the main beam that goes across.
