Carb Tuning: AFR’s with gasoline containing ethanol
I am in the process of starting to tune the Quick Fuel SS-750-AN double pumper with electric choke carb in my recently completed Mk4 build. I have installed an O2 bung in the collector of the PS pipe, and have a new Innovate LM-2 AFR wideband meter wired up and running. The only downside is the inductive pickup doesn't work with my MSD ignition. The Innovate instructions warned about this, and they're right. I could fish around in the wiring harness to find the tach wire, but really don't want to go there. For test purposes, I'll do without and carefully log each run using the tach on the dash.
This is all pretty new to me, so an interesting learning project. I’m using the excellent Carb Tuning 101 instructions from Wayne Presley, following a couple other tuning threads, and just reading and learning as much as I can.
First some basic info. The engine is the DART 347 in my Mk4 Roadster with AFR 185 heads, relatively mild COMP Cam custom cam, Air Gap intake, MSD ignition, BBK/FFR 4-into-4 headers and GAS-N side pipes. Compression ratio is approx 10.5, and I’m running premium pump gas. This will be nearly 100% street cruising, so want a nice drivable final product without leaving a lot of power behind of course. The carb came with Primary Jet: 72, Secondary Jet: 80, Idle Air Bleed: 71/71, Hi Speed Bleed: 33/33, Pri Nozzle: 31, Sec Nozzle: 31, Needle & Seat: 110, Power Valve: 6.5. Other than adjusting IMS, I have replaced the primary jets with 68’s when it was clearly way rich in cruise. I’ve driven it a couple hundred miles before installing the LM-2 and starting this tuning. It starts, runs and drives quite well. But it’s clearly rich based on exhaust smell, plugs, and the extra fast moving gas gauge.
So here’s where I’m at so far. I’ve confirmed the timing is 14 BTDC at idle, and all in at 34 at 3,000 rpm. The distributer is mechanical only. No vacuum. I went to lighter springs to get this curve. Didn’t have to change the bushing. The mechanical fuel pump pressure is indicating exactly 7 lbs. Fuel in both bowls is exactly splitting the sight windows. I set the T-slots exactly like Wayne’s directions. About .020 exposed on the primaries and just barely peeking through on the secondaries. It idles pretty OK at 750-800 RPM. I initially adjusted IMS with a vacuum gauge (before the AFR meter) and it was about 11 inches. All four screws were between 7/8 and one turn. With the AFR meter installed, found that it’s idling at 12.1 – 12.2 AFR. First recording session, per Wayne’s instructions (3rd gear, light accel from 1,500 – 3,000 RPM) showed slightly rising AFR from 12.1 to 13.0, average 12.82 over 35 seconds recording. Before changing any jets, went back to the IMS and adjusted some more. Found that the idle increased slightly, smoothed slightly, and vacuum now at 12 inches. All four screws now at about 5/8 turn. Any further didn’t do anything. AFR was slightly higher at idle, but still well below the target of 13.5 – 14.0. I ran another 3rd gear, light accel from 1,500 – 3,000 RPM session and the AFR is again slightly rising but now from 13.0 to 13.5, average 13.08. Going in the right direction with only changing IMS. Unfortunately now I do have an occasional hesitation coming off idle. Other than that, is does run a bit cleaner and crisper than before.
Sorry for all the detail and background, but needed to define the starting place. I have a ways to go to get to the AFR numbers in Wayne’s tuning post. Before I start chasing that, I’m reading in multiple places that target AFR numbers with ethanol based fuels are slightly lower. All regular pump gas in this area has ethanol. The only place to get without is at marinas, and I’m not going down that path. I typically run either Shell V-Power or the premium brand at Costco. Both say on the pump that they contain up to 10% ethanol. Per Wayne’s instructions, my AFR goals should be:
13.5 – 14.0 at idle
13.5 – 14.0 in light cruise
12.5 – 13.0 on the primaries
12.4 – 12.8 with the secondaries added
First question: Are these still valid with ethanol based fuels? I don’t want to throw parts and time at this thing trying to get those numbers if they aren’t the right ones.
Second question: Any words of wisdom regarding the initial tuning I’ve done? All the basic settings are checked and re-checked. All is tight, no vacuum leaks. I think I’m all in on the IMS setting. Reducing the IFR’s should raise the AFR in light cruise, but wouldn’t that make my hesitation off idle worse? Obviously there are more tuning steps to go, but just getting started in the proper sequence.
Thanks all.
13.5 – 14.0 at idle
Thanks all.
