Noticed a bit of a wet spot under my left rear, so I pulled the caliper off, and it seems that the leak is from the pivot point, for the auto (e-brake) adjustment. This caliper is from the 88 turbo-coupe.
I noticed previously, when I was turning the piston back on this caliper, for new pads, that it was very hard to turn. Could I have damaged a seal in the process. I'm not positive how this pad adjustment mechanism works, any ideas?
Is the seal for this bolt available, and a simple replacement job, or should I just get an exchange caliper, and be done with?
Thanks, Bill
Thanks, Bill
