Guys:
Need some advice.
Have 99 GT PBR front calipers with 11" rotors from Breeze. The hole for the banjo bolt on the left front caliper is stripped. Planning on running a manual mustang brake setup with 15/16" master cylinder. I have the 17"x 9" Halibrands from FFR on the front.
Options that I can think of:
1. Drill out and use a thread repair kit like Helicoil. (is this safe...will the bolt seal - I think so, since seal is from copper gasket, but I don't know... will debris in the caliper cause brake malfunction???)
2. Replace the caliper with same model - might be hard to find...
3. Upgrade to "better" caliper...which probably also means bigger rotor etc. and bigger cost. This is not my preferred option but I am willing to be convinced.
Any other options? Opinions?
Rick
Need some advice.
Rick
