Vent hose inside fuel filler neck?
1 reading
370 views 8 replies 5 participants last post by  Coshee
#1 ·
Do you need an air vent tube inside the fuel filler neck when you extend it. If so, pics please.
napatom
#2 ·
Most just remove it. You may loose the ability for the auto shutoff on the pump to work when you are filing up but not a real big deal. Really is your choice.
Todd
#3 ·
You do not need to extend it. Just cut the metal pipe without cutting the hose, add the extension. The hose ends up where it ends up. I think it serves a purpose and should not be removed, but it is not critical to function.
#4 ·
I talked to Mark at Breeze and he says the same thing as sgspeed.
Just cut the metal tube and extend it , and leave the inner hose inside it is suppose to help keep the fuel from burping out of the filler.
#5 ·
He Dan...
Guess where I got the info... I bought the filler from breeze...It came marked, cut here.
#6 ·
Thanks guys, but the reason I asked is, there is no hose inside the filler neck, only a metal trough soldered along the length of the neck to allow air to escape up the filler. It had to be cut to separate the halves. I thought it might need a hose added to the length to bridge where the inside metal was cut.
napatom
#7 ·
It is not totally necessary, depending on how hard it is to put in the hose you could do it or not.
#9 ·
sgspeed,
We must both be real smart then. I better go write it on the calender because my wife says it doesn't happen that often. :D
