I have the SW gauges and 185 degree thermostat in a 302 EFI. When I start the car, the temperature gauge climbs immediately to 280 degrees, even before the thermostat opens. After the car is up to operating temperature, the gauge stays at 280 degrees. As soon as I cut off the ignition the temperature gauge immediately drops to 190 degrees. I have checked the ground and it is ok. I have also checked the temperature of the hoses with an infrared pyrometer and am getting between 175 and 185 degrees. Does this sound like the temperature sending unit is bad?
Jimmy
FFR2203
Jimmy
FFR2203
