Just finally finishing up the dash wiring and need a bit of help. My wiring harness doesn't have any magical provision to connect all the different diodes, etc... for my turn signals, flashers, emergency flashers, brake lights to all work and play together so I need some help.
A good wiring diagram would help, along with part numbers for the diodes I will need. I believe it will take 4- 2 diodes for the emergency flashers, 2 for the brake/ turn signal lights.
I am using the VW turn signal assembly on my column. Will those wires handle the turn signals, or are you guys using a relay to handle the turn signal current?
