I'm seeing a mix of opinions on whether to run coolers and the conclusion is that I may not need to for the tranny but for the engine I remain a little concerned about the smaller Petersons 6 quart tank. A few questions concern location, size, fans or not and whether an additional pump might help.
As for the transaxle, I found a good deal on a nearly new Setrab 51-07944. Setrab Differential / Gearbox Coolers | susa
I also purchased an inline -8AN thermally controlled switch for a fan. I assume a pump like a Tilton is needed due to the viscosity and need to push the oil through the cooler because there isn't an internal pump in the trans. I have not bought the pump yet.
As for the engine, I am trying to keep things compact and looking for a reasonable solution, not excessive in size but something that keeps temps from getting out of hand.
a.) Is the preferred oil pickup location between the Petersons tank and dual port on the right side (GTM) or the left where the original oil lines for the cooler were routed. If inline with the oil filter, I would need a separate adapter and possibly have the headers in the way. Not sure but asking to see what guys have done. Shane gave me some good tips concerning oil capacity and being careful to not overfill. I never did figure out whether a cooler is really recommended and where the best place was to plumb the lines.
JM
JM
