Location and size of grounding bolts
8.7K views 3 replies 4 participants last post by  Bob McLaughlin
What you propose will certainly work. But, it is overkill as none of the electrical ground will carry enough current to need such large grounding bolts. Simple 1/8" self tapping screws with star washers will work just find. As you said, sand off the powercoat or paint, put in the ground, attach with wire and then spray paint over it. That will protect it from rusting.
