Jack,
Once again you have been accused of not heeding the good advice given and going off on your own. I now can see why you are in the profession that you are in, because you can go to work and take out all your frustrations:001_tt1:.
I read your original post and you specifically asked if there was a manual solution to the situation that you personally have with your vehicle. The very first response was about the solenoid, which I might add seems to be a very good solution, however you originally asked if there was a manual solution.
While the solenoid method probably makes the most sense, that is not what you were looking for.
In the past I have read many of your posts and have seen many times when advice was given and you veered away from some of it, and I have to say I commend you for at least thinking about your problems and using this board as a sounding board to get opinions about what you thought was a method for resolving some of your problems.
I have to admit that in some cases the solutions that you have thought out might not be perfect, like storing spare gas in a space near a wheelwell or something like that where it can fall out, but you at least are always trying to come up with a fix. And thats what these cars are all about, it is your car and you customize it with little contraptions that you like.
Human nature dictates that if someone makes a suggestion to another person they believe that their suggestion is the only way you should proceed from that point on, and I can understand that because they are passionate about the suggestion they made to you.
Is a manual cable the way to solve this problem, maybe, maybe not. Is an electric solenoid the way to solve this problem, maybe, maybe not. You would like to try a manual fix based on your original post so after all the bable I just typed I would offer this.
Yes, I believe there is a way you can do what you would like to try. You could go to a parts store that sells heavy duty truck parts. There they would have Power Take Off (PTO) cables and manual throttle cables for using the PTO. The throttle cables have a knob with a very fine thread adjustment that would raise the RPM to what ever you want and then you can lock the knob at that level.
Also the end of the cable has a slot so that the throttle linkage attached to your accelerator will still operate. Will this work, maybe, maybe not, but it is your idea so keep up the good work. I for one enjoy reading your posts with your various ideas for problem solving.
BigUgly
