Iditit or Flaming River steering column conversion for Mk 4
136 views 5 replies 5 participants last post by  Herb427sc
#1 ·
Good day all
I’m interested to know from any members as to the viability of installing an aftermarket steering column of either IDIDIT or FLAMING RIVER manufacture in a Mk 4 Roadster primarily to gain a direction indicator stalk
Thanks MG
#3 ·
The 33 hot rod comes with an IDIDIT column. The turn signal/hazard switch plugs directly into the Ron Francis harness. It is available as a tilt or non tilt.
It has brackets that bolt to the pedal box on the 33 frame, not sure if the MK4 is the same or not.
#5 ·
The only one I have ever seen also had tilt. That made it stick way out of the dash so the wheel was much closer to the driver than I like.
