(I also posted this on the cobra grandstand)
Ed,
I powered up the harness for the first time last night. You can hear multiple relays engaging upon turning the ignition key. So far so good. The starter will engage, that's also good; however, I did not hear the pronounced fuel pump whine. I checked the voltage at the inertia switch and it is reading 12 volts across. I checked the Fuel pump relay and it is powered. I lastly checked the voltage at the pump itself, after playing for a little while I was able to get a reading of only 7V. I jumped from the fuel pump connector to the fuel pump and the pump activated but barely, it sounded like the voltage was too low. So where do I go from here????
Does 7V at the fuel pump sound correct? Could this be a ground problem? If 7V is not correct, where could I be seeing a Voltage drop? I am planning on running a jumper from the battery just to test that the pump truly does work.
Any thoughts?
Gara
Ed,
Any thoughts?
Gara
