Update- bypassed the switch Craig S recommended and
- rear parking lights now coming on and I won’t go off
-gauges now light up
- cannot start the car as ignition switch isn’t working
Good Grief...So in other words, the typical electric confusion that happens to us non-electrical types ..😣😄
My first thought of testing the battery master switch would be to just use a simple 12volt test light. With the battery positive cable hooked up to one switch terminal, run one lead of the test light to the other terminal on the switch, and the other lead to ground. Turn the switch on and off and see if the test light works. If you tap the switch gently when the test light is on, does the light flicker, or go off?
So before bypassing the battery master switch, the
rear parking brakes didn't work, but now they do? Did only the front parking lights work before? Do the front parking, and headlights now turn on and off Ok with the headlight switch, but the rear park lights just stay on? If so, this sounds like a wiring issue unrelated to the master switch. Your positive it wasn't the brake lights that were on? Maybe your, or a friends foot was resting on the brake pedal while you were checking things out. Seriously, it's those kind of crazy ass things that happen to some of us, that can drive us nuts.🤪
You say the dash gauges
now light up, even though the ignition switch isn't working. This indicates that they are on a non-switched, (always hot), circuit, which typically is how most builders would wire our park and headlights. In other words you can turn on the headlights, (and park lights), anytime, using just the headlight switch, without first needing the ignition switch in the on position. Of course the master switch has to be on to do this.
Besides the headlight/park switch having to be turned on, dash lights are normally wired through a dimmer control switch, some which will allow you to turn the dash lights off altogether. Do you have an instrument light dimmer switch? If so, is there any chance it could previously have been turned down to the point the dash lights were not visible? If not, then the fact the dash lights
now work having bypassed the master switch, it may indicate an issue with the master switch itself.
When you say you cannot start the engine because the ignition switch isn't working, do you mean the starter is not cranking, or that it cranks ok, but the engine won't run? Having a separate "start" button, could it just be the "start" button that has failed, (or perhaps it's wiring).
It begs the question, has bypassing the master switch allowed the ignition to be turned "on" now? Does the car now have 12 volt power available, be it via switched or non-switched, (always hot), to all circuits? Check the switched circuits, wipers, heater fan, or perhaps you hear the electric fuel pump running when the ignition switch is first turned to the
on position.
