I have Crane 1.7 roller rockers, stock push rods and a FMS F303 cam. Rocker covers are aluminum. There does seem to be quite a bit of noise from the valve train. Is this normal for my settup ?
This happened to me. I thought that the noise was normal for roller rockers. The edge of the rocker arm was actually pushing down on the spring retainer before the roller tip contacted the valve stem. This caused the little retainers to rub themselves smooth and I dropped a valve. I replaced the Crane roller rockers with FMS and had no further interference. It is worth checking. You will be able to see the rub marks on the top of the spring retainer.Originally posted by Wurf:
Also make sure if you are running the Crane "Cobra" or vacuum formed, Cast aluminum rocker arms, the rocker bodies are pretty thick at the roller tip. Some valve and retainer setups have shorter valve stem tips and the rocker body may actually contact the top of the retainers. This is bad, unkay....ask me how I know.
