Brian I seriously doubt you’re trembling at the prospect of my little project with a Snake capable of the mid 10’s... in street trim yet... and pulling that front end off the ground in second... with those ground shaking 7 grand shifts. But you brought a smile to my face.
I’ve always known a good set of heads could produce decent street power for the amount of dollars invested. I just didn’t know which set of heads from all of the good ones out there would be the best set for my SB application. And I was looking for bolt-on power with as few extra mods as necessary. It was this Car Craft Tech Article
400 Horsepower With A Stock Cam! By M. King that got me to thinking about the best heads for my application. I found the info I was looking for. CC obtained 400 HP from a bone stock short block with as few extra mods they could get away with... without even a cam or pushrod change! That article made my eyes pop out.
My setup consists of an Explorer GT40 replacement block with unmodified iron GT40 heads. The only mods on it were the addition of Ford’s E-303 cam, Crane 1.6 Rollers and HD Valve Springs and Guides. An Edelbrock F28 and two Edelbrock 1404 Manual Choke Quads were recently bolted on to the upper end. Period. We figure we’ve got about 325 HP right now... the same figure we used before the upper end addition. I know the Ford “E” cam isn’t the best available but I’m going to try to get away with leaving her in.
The results in this article in FordMuscle
AFR's 165cc SBF Head Flow Testing by C. Asaravala leaves little doubt at how well they perform. This is also a head that it seems one could get away with without having to notch the pistons as opposed to the 185’s leaving the 165’s looking like a true safe bolt on proposition.
Randy,
Jerry Comp Cams adds a little “Pearl in the Oyster”. The CC Tech guys didn’t even have to change the pushrods probably because Comp Cams offers the perfect product for this application with its aluminum adjustable 1.7:1 roller rockers (PN 1054), which bolt onto the stock cylinder-head pedestals and allow easy valve adjustment with a pushrod-cup adjuster nut. They had the valve gear swapped in about 15 minutes (they didn't even have to change the pushrods).
Jerry,
“...the 165's are capable of more than 400 HP on a 302.” That’s what I’m hoping for!
CompCams® Adjustable Aluminum Pedestal Mount 1.7 Roller Rockers PN: 1054-16
Save for the addition of Comp Cams 1.7 adjustable rollers and maybe better flowing headers I hope to escape having to mod the block too much further with the end result of an additional 100 HP at the crank! At least that is what I’m hoping for finished up with a little fine-tuning on the local dyno.
Phil that sounds like a decent deal for someone who would want to use their stock cam to really keep expenses down.
So
Dan you see... my motor is essentially pretty close to stock. That is why the 165’s look so good. With flow performance like that why go to the 185’s if I’d have to have the pistons notched or replaced adding further expense? Did you have to notch your pistons with the 185’s? And what are your other engine specs?
Anyone running the AFR 165’s and if you’re running the 185’s did you have to notch your pistons? Anyone get away without having to notch ‘em?
Edited for grammar... and photo addition.
[ February 05, 2004, 04:02 AM: Message edited by: BobAruba ]
