I’m looking for some help on jetting my carburetor. I have a 392 stroker SBF, 10;1 CR, roller cam Comp Cam XE 282HR-12 with intake at .050 lift 232 degrees and exhaust 240 degrees, Holley 4150HP 750CFM, Victor Jr heads, Victor Jr intake, MSD distributor and MAS 6AL. Problem is idle richness. I have the float level set just below the threads. Also the engine idle speed almost comes to a stall when I do a fast stop. I can’t get the engine speed to change much no matter what I do with the idle air screws and must set the throttle up to keep idle speed up. The exhaust smells of fuel at idle. I also get bad fuel mileage in town, 10 MPG and only around 12-15 on the road, this is in a 2200lb Cobra with 3.55 gears. It also starts to load up when I do auto-x type turns. I have the timing set at 34 degrees total using the 18 degree spacer in the distributor. Reading some infor on the web said I might try drilling an air bleed hole in the butterflys to lean up the idle mixture because of the cam over lap, but have never done this before so am looking for some help.
Anybody offer any help in the form of info or West Palm Beach tuners that know how to get the carburetor to run right.
Paul
Paul
