1 - 3 of 3 Posts
The body of the GTM is typically done with a Painless body harness or similar. For the engine, you will need an aftermarket harness or the factory harness specific to you engine.
Aside from the engine, you dont need many of the Corvette plugs. I think you need the power window steering column and wiper plugs and maybe a couple others.
I have a GTM with no wiring, what should I do for all the plugs I need? I found a 2002 Z06 interior wiring harness, will that work as a start?
Hi Al,
The C5 corvette has three harness. What plugs are you looking for?
Are you using a crate or donor engine?
What tanks and pumps are you using?
I have a new painless kit i did not use and I have a spare 2003 interior and tank harness, 03,04 tanks are different.
1 - 3 of 3 Posts
