When I install the doors, they are about 1/8" low on the front and back edge. The doors studs are as high as they can go in the hinge holes and the hinge is as high as it can go on the hinge-frame mounting point.
I've tried hogging the holes out some, but it's hard to elongate the holes on the backside. This is a problem because I think when I'm thightning the bolts down, the bolts want to go as straight through the holes as possible and they creep down.
Also, what type of relationship should the hinge rotating point have to the body/ground/floor, etc.
I.e. should the hinge be perpendicular to the ground, or at an angle, etc.
TIA..
TIA..
