snowsnake,
You'll need to get a MAF that is matched/calibrated to the size injectors you will be running.
What size injectors do you plan to run?
George
· Senior Member
The cnl will work for your your throttle body size. Also have a proM 75mm that's set for 24's. It's 175. Both are in like new condition.
So far I'm running 19lb. injectors, 55mm throttle body and stock MAF but the engine needs more air.
I have a 65mm throttle body sitting in the garage but need the MAF to go with it. Don't know if I will have to bump up to 24lb. injectors yet.
· Senior Member
The C&L will be fine... You can go 19 pounds and change if you wish. All you do is loosen 2 screws and change sampling tubed. I had a 70mm throttle body but went a different way with my build.
