1 - 2 of 2 Posts
That is the diagram I based my drawing on. I tried as it is drawn. That is why I modified it. With that set-up, if you go from off to fast the circuit breaker/fuse will blow. If there is a momentary loss of power as you switch from slow to fast, the circuit breaker/fuse will blow. If the ignition switch is turned on while the wiper switch is in fast, the circuit breaker/fuse will blow.
All of these things were true using my Lucas motor. From what I've read on this forum Lucas quality control is erratic. Perhaps my motor is defective and the drawing on the geocities site normally works fine. Be aware that the large diode on my drawing needs to be rated for at least 3 or 4 amps.
1 - 2 of 2 Posts
