Hey Guys
I was installing the rear brakes (Wilwood Group P/N 140-12363) and it looks like there is a interference point with the knuckle and the lower bar that is part of the caliper assembly. The pics are DS
This pic has an arrow point to the "point" that is part of the knuckle assembly. The bracket in the back is the Wilwood mounting bracket for the caliper
This pic shows the caliper mounted on the mounting bracket but as u can see it hits the point of the knuckle.
I am assuming I should just grind it down but figured I would check with the team to see if others have seen this before. Yes I have an IRS rear. I also send the pics to wilwood and I am waiting for them to call me.
Thanks in advance - hope everyone had a great holiday!!!
· Premium Member
Hi Guys,
This is not the Wilwood IRS kit I sell. Mine has an emergency brake inside the brake rotor. I have some pictures at work if anyone has any questions.
Hi Guys,
That is true the Wilwood Kit and Knuckle can as part of the complete kit from FF5. Sorry Mike did not mean to imply this was parts from you. hope all is good..
I ran into the same thing and got the grinder out. Grind down the part protruding above the mounting bracket and all is good.
Yup that is what i figured. It was getting late in the evening so I figured I would tackle it tomorrow. Also figured no harm in asking as I have been known to put one or two pieces on backwards, etc
· Premium Member
All good
Hi,
I just wanted to let those interested in the Wilwood IRS brake kit I have that this was not a problem with what I sell.
· Premium Member
Sal--
Does the FF5 Willwood brake kit have a provision for a parking brake?
If not, I do.
Call me and I'll give you the details if interested.
Cheers,
Bob S
Knuckle and bracket conflict
Sal--
If not, I do.
Cheers,
Bob S
I have identical setup, and identical problem. Grinder solved it in 5 minutes. What have you done about e brake connection at caliper? My wilwood bracket is right next to the upper arm bolt. Assume I will need to find or make another bracket. Any suggestions? Thanks
· Premium Member
Yes, you need to make a bracket that bolts to the spindle, It is bent at a right angle and has a hole in it that the cable goes thru.
I gusseted the bracket for added strength.
