I am looking at buying a set of rear coil-overs from a Superformance and am wondering if they will fit the FFR.
Can anyone help? Any extra input would be great
Discussion Starter #2
Anybody?
Do you know what brand they are?
Can you post a photo of them?
Probably could tell with more info about them.
I have no idea what SPF has, but one could measure: Check you current ride height, how long from shock bolt to shock bolt.
If it's like 13 to 14" then the shock your buying needs to be like 17 extended, 11 compressed. If 11 to 12" then a 14 extended, 10 compressed is ok. You'll also have to make sure the rod ends are the same and the spring hats will clear the frame brackets. Also check the springs, I think FFR is using 10" springs. These are just rule of thumb numbers, so maybe take your old shock off and compair side by side to the ones for sale. Not much help...But, good luck.
