1 - 3 of 3 Posts
Can A 94 OR 95 MUSTANG rear with disc brakes be used or do I have to stick with the 86-93 housing? The width is roughly 59 inches wide vs 61 inches.
section 8
I beleive the housing ( less axles) is the same width. I have a MK7 housing with North Race cars brackets and use Cobra rear disc brakes. Depending on which brakes you want to use you'll have to contact North Race Cars. I think if you use 87-93 axles with 87-93 DRUM brakes you can use your housing Bob
Fox and SN95 housings are the same width. The axle length and caliper brackets are different.
1 - 3 of 3 Posts
