This is actually a three-part question:
Q1: What is the difference between SN95 and say 93 spindles?
Reason:
I'm looking to get a set of drag brakes for my Mustang that will fit behind 15 inch skinny rims [the stock brakes will not fit] and I do not want to use spacers to get the clearance. I'm told to swap out the 95 spindles for 93s and then buy some drag brakes or Wilwoods.
Now, if I make the swap, I have brand new 5 lug hubs on the 95s:
Q2: Will the 95 hubs fit the 93 spindles? Also:
Q3: Should I keep the 95 spindles around for the later FFR build?
Jerry
Q1: They have better built in bumpsteer geometry. They also are the first Mustang year with a sealed hub/bearing set (brake disk slips over hub and is held in place by the rim and lug nuts.
Q2: No, completely different design.
Q3: Yes, definitely!
I guess the 94 & 95 spindles are the ones to get but do they need to come off of a V8 Mustang?
All SN95 spindles are the same (in terms of V6/V8).
Btw, try for 94/95 - 96+ cause the tires to punch out too much. (94/95 have a dog leg bend in them, 96+ are straight armed)
[ March 11, 2007, 02:42 PM: Message edited by: EFNFAST ]
EFN
SN95 spindle come in two year ranges ... 94-95 and 96 - 2004. The newer spindles have are staight, the 94-95 have a dogleg. The 94-95 are 8mm narrower track per side and have better bump steer geometry. If you've got them, keep them.
See pictures in this other thread.
Do I have 94-95 spindles?
The confusing part is the way Ford named these parts. The SN number has nothing to do with the year.
Pete
Originally posted by GoGS_Racing:
EFN
Pete
I worded my post wrong - meant V6/V8 spindles are the same.
EFN,
Good to know that the V6 spindles are the same. It widens the availability for those still lookin.
Pete
