Sr FFR builder
I have read the posts but am perplexed. Every manufactured car out there that I can remember has the turn signal ABOVE the brake lights. Yet most of the posts I have read say to have the brake light above the turn signal. Whassup wit dat?
Do it any way you want. It's simply up to you.
Dan,
To me it made sense to have the brake lights be the most visible in the top position because the car is already so low to the ground, you need all the visibility you can get! I ended up using the trailer converter trick to make all 4 of them light up with brakes, and only the bottom one on either side will blink when turn signals are activeted. The other 3 will stay on the bright filament for maximum visibilty. It's your rear end - do what makes you happy, but give some thought to the safety aspect. In my opinion brake visibility takes precedence over turns...
hope this helps, Brian
Over Engineerer
Do you mean he should use a lubricated condom?
Originally posted by FFRed:
</font><blockquote>quote:</font><hr />Originally posted by B+L FFR 1686:
Do you mean he should use a lubricated condom? </font>[/QUOTE]DOH!!!! I missed that the first time around
Hey Smackdown, it just so happens that I was behind a brand new hemi Durango at a red light on Saturday. We were looking at it pretty carefully because I was explaining to my wife that it would be her next car. (Sure, honey, you'll LOVE the hemi! :D )
No question, the brake light was on top, the turn signal below it, the reverse light below that.
AJ
