I recommend Marine-Tex. Easy to mix and will give you plenty of time to adjust and line things up the way you like. Just grind the surface with 60 grit and clean. Once dry it not going to come loose. The shear strengh 1800lbs!!! If you prep right, It ain't going no where!
