One good answer fixes two cars! Got two of these things, and both do the same thing.
302's,great compression,new aluminum heads,alum roller rockers with tall baffled covers, other steel rollers, tall covers, no baffles. PVC into carb, other cover into air cleaner.
While playing follow the leader and just jumping around on the mountain roads, no obvious smoke. Little puff of black when secondaries open, but thats it. Using about 1 1/2 qt in 7 to 800 mi. No smoke on start,no smoke on deceleration. Not a drop under either car. My only guess is pulling it back into the intake at an even rate no matter where throttle is positioned(at drive speeds). Any ideas? I've run out.
Marc A
Marc A
