Pro FFR Builder and Moderator
Use a standard length stud and then you will be shortening them to the length needed.
Master Student
If you get the standard length studs, you will have to cut them in order to tighten the pins down. The pins use an allen wrench and it is difficult to tighten down unless you cut the studs off about 1/4".
Here is about what it looks like of you use the FFR pins and standard length studs. Not much room to get a wrench in there to get the torque.
I kept the standard length studs and got the Kirkham pins. You tighten them with a socket. they are much better.
