I was mounting my the donor wheels so I would have a roller and noticed that the stock studs extend past the wheel spacer surface interfering with the mounting of the wheel. I removed them for now as I will likely sell the wheels I previously purchased for a different set. My question is; is it standard that the studs have to be shortened if you use them or did I hace them on wrong?
craftsman
Yes, you trim them down. An alternative that we did on the race car was to change them out with a longer set of studs from summit and rotated the spacer to the stud holes. It has worked for four years now with stock wheels as well.
RM
I had to cut mine as well
