121 - 140 of 175 Posts
Curious George
got the pedalbox back on track - still waiting on parts, but at least it's setup for hydraulic clutch and Power Brakes now
plus I painted the raw aluminum to keep the black them going LOL
358631
painted some more parts for the whitby system tonight too...
358628
358629
and did some rustproofing on the driveshaft...
358630
Working on my Brown County Custom dashboard for Gen 2 Coupe. Just got dash back from being powder coated. Will try to get all gauges and switches mounted and begin wiring with harness.
Was able to get a new Centerforce billet steel flywheel for $200. Old iron flywheel would cost $50+ to resurface. Seemed like the best move with 7000+ RPM potential.
358642
Discussion Starter #127 (Edited)
The Koolmat went ok. I only was able to to do 1/4 of the cockpit before it was time to go to work.
It is much easier to make a small piece work. I tried to to do the back cockpit wall (the biggest piece). There are sections I can not stop from lifting. The smaller pieces are perfect. I will cut up the big pieces for now on like the floor board. Which I did on the PS.
I assume on the parts that are lifting I can cut a small slit and peel it back a bit and add some more contact cement. Maybe I can use my marinade syringe to squirt s little in the lifted area.
We will see after it totally sets up.
Jason
I was having issues in town stoplight to stoplight with engine temps right at 210F. No issues at speed, with temps running below 180F consistently. I had a smaller crank pulley ~ 4.6" on the 347. Went to a 6.125" crank pulley that was installed this morning - will see what difference that makes tomorrow. Of course, had to get a longer serpentine belt as part of that modification, also installed. While I was at it, I replaced the nearly 7 year old 51R battery with a fresh one. Had to take the old one out to swap out the crank pulley anyway, so seemed like a good opportunity to take care of that.
looks great! what's the weight difference?
About 8lbs. You need an aluminum one to loose weight. I was looking for strength.
Wow ....... love the cobra stencil. You may have to gets some LED’s in the cowl to light that up at night.
Like the stencil. If I had art talent would spray a silver one on my black radiator shield.
Simple enough. Print out design, tape it to posterboard, cut out with x-acto knife, light contact spray to the back of stencil, then light dusting with spray paint.
Curious George
Yeah we did something similar on my wife’s Focus ST Prepping the Mountune FMIC
Sounds good - will add it to my TODO pile. :D
Curious George
Pulled all the pedal box and panel to make a template for the Whitney power brakes
Realized I had to notch the board to fit the 3/4” tube
Top two holes line up for the Wilwood pedal box , the driver side lower hole lines up
Had to drill the lower passenger side
Serious pain - started with 1/8” in bit and worked up to 5/16 - took a break tonight need to get to 3/8
